[US] Aparte 900SPG, 1990, 185.000 mls.
Bericht door gj900 » di 19 mei, 2026 19:29
Mooi rood is niet.... of toch? :shock: Staat in Amsterdam (NY) 8)
https://www.saabnet.com/tsn/members/gal ... erID=13051
Color: Talladega Red
Trans: Manual
Mileage: 185,000
Price: $30,000
1990 Saab SPG Paint code 219 Talladega red. Since I have owned this, the entire car has been gone through. All of the Suspension removed cleaned and new Poly Powerflex purple bushings installed with new shocks. The interior has been redone with L-Seat red leather seats. The air bag system has been removed and a steering column and wheel from non airbag car installed. Also ABS braking system was removed and replaced with brake system from non ABS car. The engine was stripped and taken to machine shop and had cylinder walls honed, New piston rings and all bearings in block were replaced. Head was also done by machine shop and new valve stem seals installed. Over 6k in as many new parts that could be sourced were installed in the rebuild. The car has had about 1500 miles put on since the rebuild was completed. The SPG has a Jetex turbo back exhaust sourced from UK. Have photos from all of the work. I have a clean New York title.
900S Sport 1992 - Le-Mans
Re: [US] Aparte 900SPG, 1990, 185.000 mls.
Bericht door Saapie » di 19 mei, 2026 20:35
Gatver; dat interieur is erg …
