terugroep actie GM Saab cabrio
Geplaatst: vr 13 jun, 2014 17:40
door peterberg
Weet iemand hier iets van:
Neben dem Chevrolet Camaro startete GM drei weitere Rückrufe wegen anderer Mängel. So gibt es bei der mittlerweile abgestoßenen Marke Saab Probleme mit den Sicherheitsgurten im 9-3 Cabriolet. Die Zahl der seit Jahresbeginn von Rückrufen betroffenen Wagen steigt damit weltweit auf fast 16,5 Millionen, davon 14,4 Millionen in den USA.
bron: http://www.orf.at/#/stories/2234021/
Re: terugroep actie GM Saab cabrio
Geplaatst: za 14 jun, 2014 4:57
door levensnevel
gevonden Peterberg
qte...
GM Proactively Announces Four New Recalls
Fri, Jun 13 2014
...unqte
en
qte...
28,789 Saab 9-3 convertibles from the 2004-2011 model years for an automatic tensioning system cable in the driver’s side front seat belt retractor that could break. If the cable were to break, seat belt webbing spooled out by the driver would not retract. The convertibles and sedans were investigated at the same time, but the convertible parts were not identical to the sedan parts. GM has since learned of customer complaints to the NHTSA for the convertibles. Dealers will replace the driver’s side retractor in the recalled vehicles. In addition, GM has issued a special coverage, so that if the same repair is required to the passenger side retractor it will be covered for the life of the vehicle. GM also extended the special coverage for passenger side belt retractors on the 2004 Saab 9-3 sedan from the original 10-year coverage to the life of the vehicle, like the convertibles. GM is unaware of any crashes, injuries or fatalities due to this condition.
...unqte
de bron:
http://www.gm.com/article.content_pages ... ecall.html" onclick="window.open(this.href);return false;
met dank aan Simik Ghookasian‎ uit de FB groep Los Angeles Saab Club
https://www.facebook.com/groups/187960801006/?fref=nf" onclick="window.open(this.href);return false;
Geplaatst: do 14 aug, 2014 10:56
door rdehaan
De grote vraag: gaan nederlandse dealers deze gordelspanner ook vervangen of blijft het een usa actie.
Geplaatst: do 14 aug, 2014 12:54
door 2masterblaster2
Mijn garage in België weet nog van niks..dus afwachten wat ze gaan doen ermee.
Geplaatst: do 14 aug, 2014 13:07
door Baasrijder
Als ik het goed lees, is dit euvel niet landgebonden....
