bijna compleet...verde900 schreef: Rover gasturbine
Makkelijke raadplaatjes (deel1)
- Donateur (9x)
Zo beter?Zaap schreef:bijna compleet...verde900 schreef: Rover gasturbine
Legendary Rover BRM Le-Mans Car
Rover 2S150 Specification
Power Output..................................................100-150 Bhp
Compressor RPM............................................64,000
Power Turbine RPM.........................................47,000
Compressor......................................................Centrifugal Impellor
Combustion Chamber........................................Reverse Flow Anular with Six Sprayer type Burners (Single Can in Automotive Versions)
Compressor Turbine..........................................Radial Inflow Impeller
Power Turbine...................................................Axial Flow
Layout...............................................................Twin Shaft, Over Hung Gas Generator with Reduction Gearbox or Compressor
Starter...............................................................Electric Motor
Ignition..............................................................High Energy Ignitor with Air Pump for Burners (MK10501)
Fuel System.......................................................Piston Fuel Pump with Centrifugal Governors and Temperature Control
Lubrication.........................................................Return system with pressure and scavenge pumps, external oil tank.
Oil Spec.............................................................OX38, 0149, Aeroshell 750.
Applications.......................................................MK10501 Air Compressor in Nimrod Aircraft, MK10401 Accesory Drive in HS748
Rover BRM Le Mans Sports Car, Rover P6 Turbine Saloon (Fitted with Heat Exchangers), Motor Boat Engine. Gas Generator
for CT3201 Turbojet engine.
Mr. Verde heeft het voorzetje gegeven en verdient dus de eer.
Zaap
I'm impressed. En wat betreft Verde; je hebt gelijk, hij mag zijn gang weer gaan.gj9000 schreef:
Zo beter?
verde900
- Donateur (9x)
verde900
- Donateur (9x)
verde900
